Hi Forum users,
I have a 2008 Escalade ESV. My front power seat only partially works, the forward/aft and the recline switches are curtailed to a slight movement forward or back then it stops. I wait four seconds and it will move again a 1/4 inch. I did some research on this and only found a couple non Chevy suggestions. I installed a new switch but to no avail. I checked the fuse and it was good as expected, since there is some movement, one suggestion was to check/replace the seat relay and the other was to check/replace the seat circuit breaker. I switched the passenger circuit breaker with the driver CB and no change. I do not know where the seat relay is. Has anyone had a problem like this? Any suggestions?
Anyone know where the seat relay is located?
Any help would be appreciated.
Thanks, JB
Thanks, JB
