2002 ETC, 2004 GMC Envoy
My drivers window switch quit working. Can you pull the switch panel up without removing the whole door panel?
Thanks In Advance!
1999 Cadillac DeVille
Thanks In Advance!
yes (took from the service manual ) 2002 ETC
Power Window Switch Replacement
Removal Procedure
Click here for detailed picture of above image.
1. Use a 13 mm (0.5 in) wide flat-bladed tool in order to pry up on the rear edge of the trim plate.
2. Insert the blade 19 mm (0.75 in) into the door trim in order to engage the retention clip.
3. Firmly press the flat-bladed tool towards the switch plate (1) for the LF door.
4. Disconnect the electrical connectors (2).
5. Firmly press the flat-bladed tool towards the switch plate (2) for the RF door in order to disengage the retention clip.
Notice
The retainer clip must be fully disengaged before the switch plate is removed. Otherwise, damage to the switch plate could result.
6. Pull the flat bladed tool upward while pressing firmly toward the plate.
7. Partially pull the switch plate (2) from the trim panel.
8. Disconnect the electrical connector (1).
9. Remove the switch plate.
10. From the back side of the switch plate, gently pry the locking tabs in order to release the following switch (s):
* Power window switch
* Power mirror switch
* Memory function switch
Installation Procedure
1. Install the following switch(s) to the switch plate:
2. Press the switch(s) into the switch plate in order to engage the locking tabs.
3. Connect the electrical connectors (2).
4. Install the switch plate (1) by evenly setting the plate into the armrest of the trim panel.
5. Press the plate (1) downward in order to engage the retention clips on both ends of the switch plate. sorry but no pics it had pics just don't know how to put em on here hope this helps you out the (#'s) are shown on the pics
