Got the 2 door coup can anyone help me I can’t open my driver door anymore and my inside circle door button don’t work to open door just the emergency open lever in the bottom works, when I use the outside button and small circle inside button my window moves a little like it wants to open but it doesn’t
You can try cleaning the assembly, but it may need replacement.
This is a C6, however the procedure is the same.
  • Helpful
Reactions: silversport
2013 Black Diamond CTS4 Premium Coupe (sold-09 CTS4 DI Black Raven/Ebony)
While you can clean the switch, this does not appear to be the primary cause for your problem.
Since both the outside switch and the interior switch are not working as expected, the most likely issue is the latch actuator.
If the exterior switch was the problem, the interior switch should still work, and vice versa. That does not rule out a wiring issue to the actuator though. Before replacing the actuator, check for proper voltage being sent to the actuator when either switch is activated. That will tell you if the wiring is OK, and if the switch is operating as desired.
