205 cts-v
Just been informed by dealer that my drive shaft needs to be replaced (70000 mi) .
Is Cadillac doing anything?
this is ridiculous . I have already replaced the differential once.
HELP
2005 CTS-V Maggied
What is wrong with it? Do you notice any cyclic thumping noises when you drive the car?
The driveshafts don't normally "fail". The carrier bearing rubber usually starts to degrade and fall apart.
There is a guy on the forums that sells replacement driveshafts with upgraded carrier bearings and mounts for a few hundred bucks if you have to replace it.
2005 CTS-V Stealth Gray stock (unmodded and happy this way)
I've seen a recall on the pinion seal. Also saw a TSB on the flex plate (if your driveshaft is so equipped). I had the dealer repair mine before I bought my car (used) as there were thumping sounds from the differential when I took the test drive.
