2003 Cadillac STS
I am having a problem with the DPM fuse. With the 10A fuse plugged in, and the car shut off with all doors closed i have what sounds like a radio hum or air blowing. This stops with the DPM fuse taken out. I believe this is causing a constant battery drain. Has anyone experienced this? Fix?
Our cars have a built-in diagnostic code scanner/memory. Maybe the DPM and ancillary functions are monitored for faults. Use the directions in the proper year/model section ("Courtesy of JimD") in the sticky thread - main Seville page - titled "How to pull codes". Write down any found codes and return to the sticky to open the link to definitions of all OBD-II codes. Write down your codes and definitions and post it all here.
2003 Cadillac STS
Didnt get a chance to go through thise steps, but after taking things apart, found the fan in the drivers side seat constantly running. Not sure as to why this would be happening with the vehicle off, but after just disconnecting the dricers side seat fan, battery drain has been eliminated.
