I have been using 20 50 oil in the hotter months of the year in all my cars and never had trouble with oil flow. I didnt use it in winter obviously. May be different for the Northstar, but for the small block Chevies and similar, it was fine. Poeple always said tge same thing, new engines are designed with clower tolerances, wont work, blah blah. If you look up the tolerances of a old sbc from the 60's and the last LT1 in the Camaro(1st gen style) of the late 90's, they are the same or very close. Only reason maker advised using thinner oils was for gas mileage, thats all. The thinner oil containers even say fuel saving on them. Engine tolerances were pretty much tightened up as much as possible by then. BMW and Mercedes use 5 50 oil in a lot of their cars, you think they use sloppy tolerances in their expensive high po engines? I bet the northstar has similar clearances as the chevy, or any other standard vehicle engine.
