Raven, All the speakers are low, not sure on the 2v or 4v pre amps.(I have to check on that, but I don't have a bose system) I have un wired and rewired the speaker connections several times and no change. I even went to radio shack and got what I thought to be better RCA cables and still no change. I did exactly as the write up says for the speakers...... I cut one end off a set of RCA jacks, Tied the Right side positve and negative speaker wires together and tied them to the right side RCA jack, I was unable to get that drain wire on the RCA jacks to tie into the other drain line so I just cut the RCA drain line off. Then stripped the insulated line back and tied that into the Right side positive and negative wires I tied together. I did the same thing for the left side. Sound right???
