1995 Deville
i have a 1992 sedan devillle. the lf door wont open from the inside and the rf barely opens. it almost seems like somthing is stretched in there. the inside handles pull out as far as they can go.the back you hardly have to pull but they are used a lot less. is this a common problem,what has to be done to fix this. opening from outside works fine. thanks for any help.
02 eldo collectors series, 98 eldo, 97 deville, 96+94 SLS,
I am guess the inside handle is messed up, my 93 does the same thing, but it still works so havent messed with it yet, my 90 coupe doesnt do it and has 60,000 MORE miles than my 93 on it, weird, huh? Just figured I would let you know your not the only Caddy owner with that problem!!
JACK
I had the same problem. I took the panel off the door and messed with the rods. The rods had gotten moved around somehow. Simple job to do, but it is a tight squeeze. Arm was hurting for days!!!
