Hi
I have a fairly major size leak in the driver's foot well (high amount of fast rain will make the drivers foot well carpet show water), i also have a smaller leak in the passenger drivers side foot well (its more at the pillar between them, will post picture late).
I think i have worked out how this is possible (with the assistance of internet searching), the door wire boots, theres been a few who have tracked down these leaks to those. Now this would explain how i am getting water in to my drivers door as well and venting at the base somehow on the inside of the door.
I know the drivers foot well is a drip at the door wall kick panel (ive seen it, not had time to pull the plastic), what i couldnt work out was the drivers door (as the sealing plastic is still in place) and the drivers side passenger, however its in an identical location to the drivers foot well just in the back and also lines right up with the door wire rubber boot.
Replacing those will be a pain (if its even possible), i am also willing to bet this will compromise all the electrics in the drivers door (as i would assume its running down a cable in the door) so might not be coincidental with my drivers door mirror / drivers door module not fully working.
Has anyone else seen this problem? (my passenger front might also very slightly "suspect" however need to resolve the above first).
UPDATE
I pulled about 1/16 liter of water from the drivers foot well, the drivers side cable boot has about 1/16 inch play in the hole, its not "sealed" it just a boot pushed in a whole in the chassis, this is a design flaw, i would assume its shrunk!!!!...
Result, i am selling the truck, ive spent about 3K on it this year, it needs another 3k in body work + everything else inside it, there are way to many bad design problems with Cadillac, i am not buying another North America vehicle, my 15+ year old BMW has minor issues, but nothing like snapping door handles or door hinges that wear out to the point you cant close the door, or a dashboard that fails.
As it is i will get Taxi for what i need in the winter months, its cheaper, i will be in pocket.
UPDATE
