The drivers (RHD car) side door mirror glass has been replaced at some point in the past by a standard piece of glass.
I'd like to replace it with the correct glass.
The backing plate (that clips onto the mechanism inside the mirror housing) is there, but someone has glued a non standard mirror glass to it.
So it doesn't dim and also, although I can hear the motor whirring, the electric adjustment does nothing. The centre of the mirror is pressed in correctly to the little cup, but there is nowhere to plug in the 3 sets of wires (I'm assuming they normally go into the glass as there is nthing on the glass backing plate?).
