Hi All,
I need to know if I can test my door handle antenna with a multimeter and what results to expect.
I plan on replacing my micro switches this weekend on my driver side door, which I know has a bad switch from testing the switches. Just thought I'd check the antenna while it's apart if there's a way to test it.
08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
I had read the procedure a while back, when mine were giving me grief. I'll see what I can find... just really short of time for a day or two.
Well I replaced the micro switches today and everything is back to normal. The antenna was obviously not an issue, thank goodness. Also learned the trick to reassembling the handle. After you know how to do it the toughest part of the job is removing the door panel and disconnecting the inside release cable.
I took a lot of pictures and plan on posting directions, cautions and short-cuts.
