1 - 10 of 10 Posts
'94 Seville STS
I have some cold air blowing by my feet, even with the heater on. I was looking under the hood, and it looks like there's a few cracks/pieces missing from the heater assembly. Does this look normal? (Nevermind the dirt, or the date on the photos). ;)
What your looking at is the heater box cover. It's a rubber cover w/ insulation in it that covers the heater box. You can only patch it with the engine in the car...to replace it the cradle must be lowered. I replaced mine when the engine was out...even then it was about a 30 minute ordeal to get it to fit correctly.
'94 Seville STS
Discussion Starter · #4 ·
Thanks guys.
What's a good way to patch this. There's a few cracks in this housing that didn't show up too good in the pics, but I think I could get some RTV sealer to seal those cracks. (Is RTV sealer what I should use, or is there something better)? Also, what would you use to fill in that missing piece?
'94 Seville STS
Discussion Starter · #6 ·
I'm finally getting this patched up today, and I need to know if I can apply the drywall tape and RTV sealer directly to the "yellow filter looking thingy" (technical term :) ); or do I need to leave a cushion of air between my patch and the "yellow filter looking thingy"?
'94 Seville STS
I have it patched. (I hope).
The drywall tape worked like a charm, and I used the whole tube of RTV. The hole was a lot bigger than I thought it was. As soon as I moved the coil pack out of the way, I was like :holycrap: . I couldn't believe that there was that much plastic missing.
I'm just waiting for the RTV to set, so I can see if this works.
Thanks for all the advice.
1 - 10 of 10 Posts
