1 - 20 of 22 Posts
1999 Eldorado ETC-sold for 2006 GTO
Hey, I've got a powerful stereo in my Eldo, and I've been having problems starting the car ever since the stereo has been installed. I checked with my mechanic, he said the battery is good (one year old Optima Yellow Top) and that the alternator is charging. He thinks that since my car is taking so much power that the alternator can't keep up. So I'm trying to find a high power alternator. So does anyone know where I could find one?
Banned
1976 Eldorado project
Can someone explain caps and why a "1.0" would be better than a "2.5" and what these numbers mean? Just curious and pretty new to the world of car audio.
How many amps does the factory alternator put out? Powermaster makes some GM style alts that are pretty high up there. I'm getting one of their 140 amps
Discussion Starter · #6 ·
I'm not positive on this, but isn't it the more farads the better becaus the more stored power. The factory alternator in my Eldo is 140 amp, but I need more.
1992 STS (4.9L, Black on Black)
Changing the CAP would make no difference at all since it does not consume any power, it just is able to try to maintain a consistant voltage in your system.
I think my 92 STS has a 200 amp alternator (heated windshield, seats etc). You could you swap your 140 out for a 200?
Discussion Starter · #9 ·
Lets see, I have a 600 watt sub amp, 300 watts total for the speaker amp, plus the in-dash DVD with monitor. Add this to all the electronic stuff the Eldo has already, and thats a lot of power for a stock alternator to have. And as to the swapping the 140 out for the 200, I'll look into that. That just might work.
Sounds more like you have a starter problem than an alternator problem. That's not all that powerful as car stereos go and the stock unit should be able to handle it. What exactly are your symptoms?
Discussion Starter · #12 ·
My symptoms are that basically everytime I start the car, it starts slow, sometimes barely at all. This morning, it wouldn't start at all, it jus started really slow, slow enough that the car wouldn't start.
94 sls
sounds like definate starter problem. If your battery tested fine and your starting is still slow then its the starter. Alternators do nothing at startup for power. If you really think its the amps then just drive the car without using them for once and see how it acts at the next startup. I wouldnt have all the equipment on at startup though. Charging up the cap and powering start up things for the car would be rough on the battery
Discussion Starter · #14 ·
I'll have my mechanic check the starter, but I'm pretty sure its ok, because I checked the battery voltage through the DIC tonight, and it said 8 volts. I'm charging it up tonight and I'll see how it is. I dunno, maybe it might jus be the battery is failing prematurely.
Starters can be pretty tricky to diagnose and the location makes it tough to get to to check it out. If the battery is charged up and the alternator is putting out the correct amperage at idle, then I would definitely look at cables and starter as the culprit. Corroded cables can also cause a starter to spin slow. Like someone else mentioned, the best thing to do is disconnect the amps (I assume you have a power wire going directly to the battery) and then drive it like normal and see if the symptoms change. Let us know any more details as they develop.
1 - 20 of 22 Posts
