CTS-V 2010
I was wondering if anyone can tell me if the 09 "V" comes with Performance Traction Management. It would be listed in the owners manual. Early articals state it will be so equiped. I know the ZR-1 does have it but have the feeling GM sctraped it for the "V" until 2010, maybe. And would it be the same as launch control?
I have a build week of july 13th for a 09. That seems close to production of the 2010 to me.
NONE
The V does not have it. The ZR1 won't have it until 2010. It's unlikely the V will get it in 2010, unless GM's released information that states otherwise.
jas
CTS-V 2010
That answers my question that PTM is a launch control system, one in the same with traction control. Sounds like a great system, to bad it wasn't ready for the "V".
So the system on the "V" cuts back on fuel as the wheels slip. Is that correct?
NONE
No. PTM has nothing to do with launch control. They're two different systems. PTM was designed to make it easier to apply throttle while on the race track. You round a corner and plant the throttle to the floor. The car figures out how much actual torque to send to the rear tires (based on various settings and parameters), and off you go.
The traction control portion of the V's Active Handling System reacts the same way GM's TCS has been working for years. It retards timing, cuts fuel, and even gently taps the rear brakes to try and return grip to the rear end.
jas
