why may i ask are you going turbo if your going to limit it to 500-550!!! Unless your leaving the stock bottom end...understandable. I believe yes you SHOULD invest in a new rear.....however the enemy of our rears is low end torque...and with a turbo I believe your low end grunt wont be much stronger then stock.....So technically you should be ok getting an 06 diff/shaft setup...and a kars stage three, but it wont be bullet proof by any means.
