OK Peeps I finally got around to the DIY version... You will need the following parts:
Silicone Intakes
3.25" to 3" Silicone Reducer (Red/Blue/Black) $12
3" to 2.5" 45° Silicone Bending Reducer (Red/Blue/Black) $20
3" 135° Mandrel Bent Aluminum Pipe $15
3.25" Hose Clamps or T bolt Clamps (3) $1.49 each for SS or $2.60 each for T bolt
2.75" Hose Clamps or T bolt Clamps (1) $1.49 each for SS or $2.60 each for T bolt
Jegs
-6AN to 3/8" NPT Adapter $3
90° -6AN Hose End Push Lock Fitting $11
Total cost about $75
I tried to use just a straight 3" coupler instead of the reducing coupler. Although it worked it was a PITA to get over the air box inlet. I trimmed of the ends of the aluminum tube to make it easier to insert the ends into the couplers. You will have to trim the 2.5" end of the 45° reducing coupler and the 3.25" end of the air box coupler. If you use a hose clamp as a guide you get a nice straight even cut on the silicone hose. I used a little silicone grease on the 3" side of the couplers to make the fit up easier.
Parts:
Sample fit up with straight coupler before any trimming.
Sample fit up with reducing coupler.
Close up of reducing coupler.
You need to drill and install the -6AN fitting.
I installed the 2 silicone fittings and screwed the clamps down just enough to hold them on. I put the tube in the turbo side first and then slid the other end into the air box end. Once you have it all together tighten the hose clamps and hook up the clean side hose.
Finished
Silicone Intakes
Jegs
Parts:
Finished
