2 1997 Cateras: black&ocean green
Check the fuses and relays. Also, a lot, I mean, TOO MUCH!!!, electrical stuff is integrated, so without the radio in the car some stuff may not work. Here's a good example: I drive around. My headlights go out. 3 seconds later the A/C panel goes out. I find #14 fuse blown. A fuse that reads "CIG", as in 12V plug... Go figure... I tried swapping relays and modules with my other Cat, but that didn't work. I checked and redid some wiring under the hood, blew about 20 20A fuses in a couple of weeks and it's back to normal again...
Catera
Thanks for the help. I put the radio back in too see if that helped but it didnt so I must of blown a fuse, I checked the one it's associated with and it's not blown so like you said I'lll have to go and check them all. Thanks again.
