Hi everyone. I have a 97 STS and recently installed a passive alarm system in it. Is it possible to disarm the factoy alarm or at least certain features of it.
Falconeo
What features would you want to bypass?
The factory alarm (horn mainly), it'll sometime disengage with the passive alarm, other times I have to use the key on the door (this in addition to disengaging my new alarm).
falconeo
Did you install it? If so, did you have any extra disarm outputs? A dry contact relay output would be perfect. Wire this to the switch in the lock mechanism that is activated when you turn your key. I would look for a microswitch, or something along those lines.
No, I had someone else install it. But I will check out the installation manual for extra output's related to disarming. What is a "dry contact relay?"
falconeo
