1 - 14 of 14 Posts
i was replacing my sparkplugs yesterday, and i took off the intake sytem for more space. as i opened the tb to wide (just messing around), i saw basically 2 tubes, one on each side of the tb, and they seemed to be realllllyyy grimy on the inside. im planning to take the tb off, and clean those tubes with some engine degreaser, or smting. is that ok? or do you have any better ideas?
2005 CTS-V, 1994 Infiniti Q45
How hard is it to remove the throttle body? Could you give a step by step procedure to do it?
unhook cables, unplug wires, and unhook any vacuum lines, and unbolt it the wrap a towl around it an gentely clamp it in a vise use some Carb cleaner (it works much bettern than Throttle body cleaner) spray it and scrub with a old toothbrush. you can do the same thing to the intake but make sure you give it plenty of time to evaporate
Do you think using parts cleaner on it would work as well and be safe on it?
like in a parts washer? I wouldnt sugest it, Parts washer will leave oily residue that will still have to be cleaned off. Also take much care with any sensors that are in the TB, Just spray them don't scrub
OK. Thanks for the help. How will i know that my throttle body needs cleaning, besides the fact that the intake is dirty. Are there telltale signs? I am from the old school engines, and i am trying to get up to snuff on things.
sooo, you do not recommend spraying throttle body cleaner into the throttle body? IF so, why not. Arent the directions on the can to spray it in there?
If you have a big carbon problem I'd suggest a product called Sea Foam but cleaning the
Kevin, what are some things that you would suggest if i do this myself. I have done this before on marine engines using similar stuff, and i spray until it starts to choke, and then i back off until it gets back to normal. Is there something that should be altered when doing this a cadillac?
Dead, i have heard of sea foam and have used it, great stuff. I have used in my 327 chevy in my 67 Christ-Craft.
1 - 14 of 14 Posts
