1990 Seville
I have a 1990 cadillac seville and my dash and my thermo display went out.. I'm not talking about the interior lighting , it's the digital display so I have no speed, fuel, or climate control display
I have a 1990 cadillac seville and one day about a week ago I hopped in my car started it and noticed my digital display on my dash and climate control completely went blank.. I check fuses was all good so hoe do I fix this
I have a 1990 cadillac seville and my dash and my thermo display went out.. I'm not talking about the interior lighting , it's the digital display so I have no speed, fuel, or climate control display,
find and fix the short FIRST -
the problems might all be related
1990 Seville
it's jest that ever since I got the car, something has been going out in my car after another, after another and everything literally is new from the transmission to the wheels and tires r new and including the water pump is alt.stsrter,ign.and tumblers,map sensors,catylitic converter jest to name a few.. I do have a hater that I believe that he's the one sabotaging my car on most of my car issues...none the less ur guess guess is as good as mine wgere that short is and if I didn't have so much .money in it, I would sell it to get my money I put in and get something that's not do much as a gas hog.. but for the year with only 96,000,00 original miles I'm thinking of rebuilding the engine as for preventive maintenance...I apologise or my emotional outburst..
2011 CTS4 Coupe, 2014 ELR, 2018 XT5 AWD
Check the instrument panel dimmer control and make sure it hasn't bee turned all the way down.
02 Seville, 04 SRX (sold), 96 Eldorado (sold), 99 DeVille (sold)
I found that my 2002 Seville did the same thing. Even though the battery would start the car, it would do that.
The battery had died, I charged it all the way and could start without a jump. Still lost instruments and HVAC. However, when I attached the battery charger and started it, everything is normal. Give that a try. You'll still need to find what is draining it.
1990 Seville
Discussion Starter · #6 ·
The car has not wen back to normal
