1 - 12 of 12 Posts
2009 STS | 2013 ATS 2.0T | 2015 SRX
Hi Guys,
I'm going to change differential mount - bad knocking
Does anyone know what is the part number and also do you change just the "front" mount or all of them (3)?
Regards,
2008 Cadillac STS
Thanks,
Yes I checked that before and only front one is damaged, the rear two looks ok but I prefere ask, just in case to avoid double labour.
Mine problem is similar when shift from R to D or from N to D the diff is jumping in broken mount. I can easily lift the diff by hand.
Also when downshift I feel the knock. Firstly I was thinking there is something wrong with tranny but when I lock the gear in manual mode and I pressed and relased gas pedal few times it's still knocking.
Differential front mount definitely need to be replaced.
2005 STS V8
I have put creative steel's bushing in my car and a friends CTS. I'd recommend it along with renting their tool..
Ohh one more question before I purchase it.
Will this fit 2009 STS as wel as?
They says it's for 2003/2007 STS/CTS for first link
and 2005/2007 in second link
My cars is 2009
2008 Cadillac STS
Sorry for the late replies guys.
BBQMaven,
revshift does not provide a special tool(at least I don't think so) for the metal sleeve, but yes you will need one. I tried BEATING it out myself but failed miserably!! I had to put everything back together and take it to a mechanic.
Wojciech,
yes it will fit your car.
2005 STS V8
If you're going to use the revshift bushing and no tool you are going to have to cut the old metal sleeve out with a sawzaw or something..
'10 CTS4 3.6L Wagon prem; '06 STS 3.6L base; '98 Seville STS
Ordered from creative steel tool included, should. The package comes with the instructions
Discussion Starter #12
Hi Guys,
Last question.
I have purchased REVSHIFT part, look solid.
What is the mount procedure?
When I remove the old part do I have to put new one back in to that metal sleeve?
Or screw up new part as is?
1 - 12 of 12 Posts
