41 - 60 of 63 Posts
Platinum 2004 CTS-V
Discussion Starter #41
Hahhaha, thanks....I'm a big fan of chicks, chicks making out, truth or dare, and both of them combined makes for a good avatar IMO
Platinum 2004 CTS-V
Discussion Starter #43
^Blasphemy!^ :lol:
Ya Ben, looks like a big chick.....and no I was rooting for the 50 yr old QB Warner!
2004 CTSV(killed), 2005 CTSV(killed that too). 2004 DTS.
Can somebody email Reed and ask him to add this to the FAQ? Or tell me where to email him at? I'd hate for this to go to waste :)
I already printed it and put it in my hard folder along with everything else I've been fortunate enough to see. I recommend it for all repair threads and maintainence threads. There are quite a few. And you have them when your under the car.
Thanks for the great addition.
Raven Black 2004 CTS-V. Broken Diff!
Does anybody have a torque spec on the rear differential bolts?
Premium Member
2005 CTS-V
Differential Housing Cover Bolt = 21 lb ft.
Differential Ring Gear Bolt = 136 lb ft.
Differential Support Bolt = 129 lb ft.
Drain/Fill Plug = 29 lb ft.
Pinion Cage Bolt = 21 lb ft.
Pinion Flange Nut = 210 lb ft.
Pinion Shaft Coupler to Differential Flange Bolt = 63 lb. ft.
so 129 lbs ft then?
thanks guys, i kinda hand torqued em, but i didnt want to overtighten them ya know
yeah i could if i wanted to, but its a good thing i asked...after i tightened them w/ a 24 inch breaker bar, turned out they were nowhere near 130 lbft. Im anal about using a torque wrench, i use em every day at work. Which leads me to the LOWER rear A-Arm bolt, anybody have a torque value on that? I went ahead and torqued to 130 considering same grade and size, but i want to double check....
• lower control arm to frame mounting bolt and nut - 111 lb ft
• lower control arm to knuckle mounting bolt - 129 lb ft
• lower shock mounting bolt - 111 lb ft
thanks! i was right on :)
Platinum 2004 CTS-V
Discussion Starter #58
Here's the pics.....not in order, but just follow the numbers.
I apologize for them not being in order, but here's the rest. If you have questions, PM me!
I've taken the write-up instructions from Lollygagger with the recent uploaded pictures, added the notes from ewill3rd, as well as the torque specs, and put everything together in a nice printable PDF for your viewing and printing pleasure. Thanks again for your write up!
Carey
41 - 60 of 63 Posts
