Ok I want to start out saying I'm posting this because I hope it helps someone else thru the install/take out process that I just went through. I'm sure the day will come when you are out of warranty, and you need to replace your broken diff. I did this not knowing much of anything about it except for what ewill3rd helped me out on as I went thru it. So a HUGE thanks to ewill3rd for answering my PM's and questions along the way.
If you don't understand something, PM me and I'll be happy to explain.
You are going to need the following tools:
21MM Socket (almost all bolts/nuts on knuckle are this size)
21MM Gear Wrench (essential that it's a GEAR WRENCH...you'll see)
34mm Deep Socket (Spindle Nut on Hub)
18mm socket
10mm alllen wrench
8mm allen wrench
Long 1/2" Breaker Bar
Masking Tape/Marker (for marking all the bolts you are going to be removing)
Beer of Choice
Long Pry Bar
Parts for new/used diff:
Two Axle Seals
Vent
Spindle Nut
Seal Protector (optional but recommended)
1st thing's first. You have to remove the RIGHT REAR knuckle assy from the car in order to get the diff out, which is the majority of the entire job.
After you take the caps off the lug nuts, Loosen up the RIGHT REAR tire Lug Nuts. Jack up your V as high as your jack will allow in Jack Stands. I did this in my driveway on my back without a lift, so you'll need to get a good amount of room to work.
Once up in the air, remove exhaust including resonator (or xpipe). If you need directions on how to do this, you shouldn't be attempting this. Once exhaust is off, remove the bolts marked (#2) in the picture. They are Allen Head bolts and are 8mm. (#1) is where the half shaft/drive shaft hit the floor board when my first diff broke. It's slightly out of round, but hasn't produced any sort of vibes (yet...crossing fingers) Put a jack stand underneath the "drive shaft" to keep the weight of the front bolts holding it to trans.
Next remove the RIGHT REAR wheel exposing the hub/caliper. You need to take the spindle nut off the axle first. This spindle nut is 34mm. Look at (#4) in the picture below. You need to place a drift punch or equivelant(I used the allen wrench) in between the slots in the rotor and the caliper. This will keep the rotor/axle from turning while you are cranking down on the spindle nut.
(#4) shows where the punch/allen wrench goes when you are TIGHTENING the spindle nut. When LOOSENING the spindle nut, the punch/allen wrench goes on the other side of the caliper in the slots in the rotor.
(#3) is the Top Caliper Bolt which is 18mm. The top bolt is longer than the Bottom Caliper Bolt so label them with the tape and marker (just to be safe)
Once the caliper is off, tie it up and out of the way. I used a bungee cord and wrapped it around the shock. Now is a good time to place a jack under the lower control arm since the bolts you will be taking out will make the knuckle assy/hub sag.
(#5) shows the caliper mount where the top bolt was. (#6) is nut holding in the Ball Joint. If you want to rent a Ball Joint Puller, be my guest. What I did (and ewill3rd does) was use a 1/2" extension for a socket wrench BACKWARDS (so the opening was facing the threads/nut. I loosened (not removed yet) the nut and then put the extension on the nut and hit the ext. with a hammer. One good crack and the Ball Joint popped loose.
(#9) Is the bolt holding the Trailing Arm to the Knuckle. Remove this one first cuz the lower control arm will sag once the other bolts are out, and it's just more of a PITA to take out. Using the 21mm socket on bolt head, use the 21mm Gear Wrench on the nut. (#8) bolt is also 21mm and needs to come out. Label the Bolts/Nuts (tape and marker) and set aside the other bolts. (#7) is just the bottom of the Caliper Mount where the Bottom bolt came out.
(#12) is the ABS Wheel Sensor. BE CAREFUL WITH THIS. Unclip it and keep it up and tucked away from everything. (#11) is the Emergency Brake Cable. You don't need to remove this, and actually ewill3rd said it was ok to let the enitre knuckle assy/hub hang by it once it was removed. <- Less work!
(#10) is the Lower Control Arm Bolt, which was 21mm. Remove it and label and set with other bolts. When you take this out the knuckle should only be held in by the shock mount bolt which is 21mm.
(#18) is the Lower Shock Mount. Remove the 21mm Bolt/Nut and the Knuckle should be free (if I haven't missed anything)
(#19) is just another view of the Trailing Arm Bolt/Nut. Sorry the numbers are out of order, I forgot this pic. At this point, the axle half will be connected to the Hub/knuckle assy still. Holding the axle splines straight with your knee and pulling the knucle towards you, it should slip out no problem. Now that the knuckle is free, place it off to the side and let it hang by the Emergency Brake Cable.
TAKE A BREAK A DRINK A BEER (OR TWO)
Ok now for the Diff itself.......
Once you get the jack (with piece of wood) underneath the Diff, remove the 21mm diff bushing screw and bolt FIRST(#14), 21mm socket on bolt head side, and 21mm Gear Wrench on nut side. (the pic was taken after the bolt and nut were removed.
The side of the diff facing the rear of the car is tight. The GearWrench is essential for getting to the back bolts. I remember having to insert the wrench on the inside of the Ebrake cable, and then once the bolt was out far enough, you have to take the wrench off the bolt head and start again on the outside of the cable. (#15) is the right rear side bolt.
(#16) is the Left Rear side 21mm bolt. Same story as the right side, and you'll want to use the 21mm Gear Wrench again. Jacking up the diff a little until the bolt is straight across helps with removal. Make sure you keep an eye on the diff when you remove the bolt, as it is the last bolt holding it in. It could wobble off the jack. When lowering the diff, it's tight getting it of the middle of the cradle. You'll have to tip the diff to one side (I did left side) so you can clear the cradle. Hold the one side of the diff with your hand (while it's tipped) and lower the jack SLOWLY watching for clearance issues. Once it's down, hold it on the jack while you pull it out from your V. ELVIS HAS LEFT THE BUILDING!!!!
DRINK ANOTHER BEER
After you admire the destruction of the old diff, it's time to change the axle seals on the new diff. I took a pic of my prybar inserted into underneah the axle seal itself. (#17) BE CAREFUL!! Only insert it so the prybar just touches the inside of the seal NOT THE CASE! This "awesome" diff case is ALuminum and you could score the inside lip and cause more probs for yourself. They pop out easily. Grab your new axle seals, put a little gear lube around the seal, and insert it into your new diff. Mine came with shipping plugs (thank you CTSV_Rob) so I turned them upside down and lightly tapped on the plastic plugs until the seals were seated. You can use a piece of wood, just make sure you hit in the center and make sure they are properly seated.
My new diff needed a vent, and you have to replace them anyways, so now it's time for that portion. (#20) shows the part I'm talking about. When you install the new vent, I used a 9/16 open end wrench around the very small lip around the base of the vent and hit the wrench with a hammer. I wasn't sure the vent could take the abuse of a hammer hit, so I used the lip to take the abuse. ewill3rd might jump in here and let us know if the vent can take a hammer hit or not. It was $19 (and dealer is across town) so I figured I wouldn't chance it.
Alright, so once the diff is ready to go, get it on the jack (holding it so it doesnt tip off) get it underneath the cradle and jack it up. Once you tip it to the side and get it up there, the left side axle shaft will be in your way.
This is where the seal protector would be used while inserting the axle shaft. I did not use one, but I was EXTREMELY careful not to have the splines grind into the seal itself!!!! You are going to have to play weeble wobble with the diff on the jack in order to get the axle shaft into the diff. BE PATIENT!!! If the splines don't automatically lineup, turn the front pinion "bell" on the diff and it will turn the gears inside (thus moving the splines). Once you get the splines to match up, it's not over. You have to get the snap rings on the end of the axle shaft to "snap" back into the diff. This was a PITA. I pretty much had to manhandle the diff and axle shaft in order to "pop" it back in. ewill3rd said they use a prybar to get em back in. I was on my back and didn't have enough room between the car and the driveway to have any leverage, so I resorted to just pushing the two together. You might have to pull the jack and diff over a little closer to the axle shaft so you don't yank the diff off the jack.
Once you get the axle shaft "snapped" back into the diff, give it a good tug to be sure the snap rings have made their final resting place. You'll know when they "snap" back in.
Once that BS is over with, it's time to put the other halfshaft back in. Same process as before, but it's much easier on the right rear side since the axle shaft is just sitting there from when you removed it before.
18mm socket
10mm alllen wrench
8mm allen wrench
Beer of Choice
Long Pry Bar
Two Axle Seals
Vent
Spindle Nut
DRINK ANOTHER BEER
