Hi, I have a '92 Sedan deVille with the Analog 85mph Horizontal Speedometer, and i was wondring if i could install a guage cluster out of a '91-96 Buick Park Avenue. It has all the info i need, speedo, tach, temp, oil pressure, volts, and fuel. I noticed that it's the same shape as the opening, and roughly the same size. But it may be too small. What i want to know is, "is this possible?" I'm pretty sure that i wont be able to use the fuel guage on this setup because of the F.D.C. already in my caddy. Otherwise, i will have to go with aftermarket guages.
Maybe the speedo would work, but remember, the buick has a 3.8 v6. so the tach wont register correctly, 6 fires per revolution vs. 8 fires per revolution. But it was a good thought, i too yearn for a factory looking instrumentation that is more than the bear minimum.
damn...i wonder if the guage setup from a 91-93 roadmaster would work?
