1 - 1 of 1 Posts
From GMCanada.com
http://www.gmcanada.com/english/vehicles/cadillac/seville/sevi_details.html
The first s or o is for the sls, second s or o is for STS
Exterior SLS STS
Antenna - Diversity, front- and rear-window integrated S S
Fuel Filler Door - Power remote release S S
Glass - Solar-Ray, tinted S S
Lights - Fog lights S S
Lights - Front cornering lights S S
Lights - Xenon High-Intensity Discharge (HID) headlights - S
Mirrors - Foldaway, heated, power remote control S S
Mirrors - Driver-side auto-dimming electrochromic feature S S
Mirrors - Passenger-side with tilt-down parallel park feature S S
Sunroof - Power, sliding glass panel with express-open feature O O
Tires - Michelin P225/60R16, S-rated, all-season S -
Tires - Michelin P235/55R17, H-rated, all-season - S
Wheels - 16" x 7" aluminum wheels S -
Wheels - 16" x 7" chrome finish aluminum wheels O -
Wheels - 17" x 7.5" chrome finish aluminum wheels - S
Wiper/Washer System - 2-speed with variable delay S -
Wiper/Washer System - Rainsense with automatic variable delay O S
Exterior | Interior | Mechanical | Seats | Sound Systems | Technical
Standard - S Option - O
Interior SLS STS
Air Conditioning - Automatic, dual-zone electronic climate control includes rear ventilation outlets with rear blower motor S S
Air Conditioning - Air filtration system S S
Console - Front centre floor console with gated shifter and storage S S
Cruise Control - Electronic, steering wheel-mounted with resume, coast and decelerate/accelerate features S S
DVD Navigation System - Single DVD for map coverage in Canada and USA, GPS based, 165 mm (6.5 in.) touch screen, voice and/or text guidance, DVD video capabilities (vehicle in 'Park' position only) and Voice Recognition (requires 6-disc CD changer on SLS); deletes rear-view mirror compass O O
Garage Door Opener - Universal 3-channel programmable S S
Instrumentation - Analogue and digital display with Driver Information Centre S S
Instrumentation - Tire pressure monitoring system - S
Lighting - Illuminated entry/exit, theatre dimming, instrument panel courtesy, glovebox, rear reading, front map, puddle lighting and trunk S S
Mirrors - Electrochromic, auto-dimming rear-view mirror with electronic compass and 3-button OnStar° System S S
Mirrors - Illuminated driver and front-passenger visor vanity mirrors S S
Package - Memory/Personalization: Automatically recalls settings for 2 drivers based on their individual remote keyless entry key fob; the recall function remembers the position of the driver's seat, exit seating positions, exterior rear-view mirror preferences, passenger tilt-down parallel park feature, climate control settings, radio station and power tilt and telescopic steering wheel S S
Steering Wheel - Leather-wrapped S S
Steering Wheel - Controls for climate, Voice Recognition, cruise control and audio systems S S
Steering Wheel - Power tilt and telescopic adjustable column S S
Trunk - Cargo convenience net with tie-downs S S
Trunk - Power remote release with Valet lock-out and trunk mat S S
Windows - Power with express-down on all windows and express-up with pinch guard on front windows and window lock-out on rear windows S S
Wood Grain Accents - Genuine Zebrano wood accents on instrument panel and doors S S
Wood Grain Accents - Wood Trim Package includes genuine Zebrano wood accents on steering wheel and transmission shifter O S
Mechanical SLS STS
Brakes - Power, 4-wheel disc S S
Brakes - 4-wheel anti-lock braking system (ABS) S S
Drive - Front-wheel drive S S
Engines - 4.6L Northstar V8 S -
Engines - 4.6L Northstar V8 High Output - S
Engine - Block heater S S
Steering - Speed-sensitive, variable-assist, Magnasteer, rack-and-pinion S S
Suspension - 4-wheel independent S S
Suspension - Automatic rear-level control system S S
Suspension - Luxury tuning S -
Suspension - Magnetic Ride Control - S
Suspension - StabiliTrak stability enhancement system S S
Transmission - Electronic 4-speed automatic with overdrive S -
Transmission - Electronic 4-speed automatic with overdrive and Performance Algorithm Shifting - S
Seats SLS STS
Front buckets with leather seating surfaces, power 6-way front seat adjusters, articulating head restraints and power recliners S -
Front buckets with perforated leather seating surfaces, power 6-way front seat adjusters, articulating head restraints and power recliners - S
Heated front and rear seating areas S S
Driver and front-passenger power 4-way lumbar adjuster S S
Rear seatback, fixed back with armrest pass-through and cupholders S S
Sound Systems SLS STS
AM stereo/FM stereo with CD player, clock, TheftLock and 8 speakers S -
AM stereo/FM stereo with cassette tape and CD players, Radio Data System (RDS), Digital Signal Processing, weatherband, clock, TheftLock and 8 Bose amplified speakers (425-watts) O S
Six-disc CD changer, located in console O S
Technical Specifications SLS
Engines
Type: 4.6L Northstar V-8
Displacement (cu. in. / cc): 280 / 4600
Bore x stroke (in. / mm): 3.66 x 3.31 / 93 x 84
Cylinder head material: cast-aluminum
Valvetrain: DOHC, 4 valves per cylinder
Ignition system: coil-on-plug cassette design with extended-life dual platinum-tipped spark plugs
Fuel delivery: sequential injection with center-feed intake manifold
Compression ratio: 10.0:1
Horsepower (hp / kw @ rpm): 275 / 205 @ 5600
Torque (lb-ft / Nm @ rpm): 300 / 407 @ 4000
Recommended fuel: 87 octane
Maximum engine speed (rpm): 6500
Emissions controls: PCV, EGR, catalytic converter, evaporative system, A.I.R.
Estimated fuel economy
(mpg city / hwy / combined): 18 / 27 / 22
Transmissions
Type: Hydra-Matic 4T80-E 4-speed electronic automatic with overdrive and viscous- type converter clutch
Gear ratios :)1):
First: 2.96
Second: 1.63
Third: 1.00
Fourth: 0.68
Reverse: 2.13
Final drive ratio: 3.11
Chassis/Suspension
Front: independent, MacPherson struts, coil springs, 28-mm stabilizer bar
Rear: independent, multi-link, aluminum control arms, lateral toe links, coil springs, solid steel 18-mm stabilizer bar, automatic level control
Traction control system: full-range
Steering type: Magnasteer variable assist speed-sensitive steering, rack and pinion
Steering ratio: 14.8:1 on center
Steering wheel turns,
lock-to-lock: 2.4
Turning circle,
curb-to-curb (ft. / m.): 40.5 / 12.34
Brakes
Type: front: power-assisted vented disc;
rear: power-assisted solid disc, 4-channel ABS, StabiliTrak 2.0 and road texture detection
Rotor diameter x thickness
(in. / mm): front: 11.85 x 1.26 / 301 x 32
rear: 11.61 x .43 / 295 x 11
Wheels/Tires
Wheel size and type: 16-inch x 7-inch, cast-aluminum, 7-spoke
Tires: Michelin Symmetry
S-rated P225/60R16
Dimensions
Exterior
Wheelbase (in. / mm): 112.2 / 2850
Overall length (in / mm): 201 / 5105
Overall width (in. / mm): 75 / 1904
Overall height (in. / mm): 55.7 / 1414
Track (in. / mm): front: 62.7 / 1593;
rear: 62.4 / 1586
Minimum ground clearance
(in. / mm): 5.4 / 137
Curb weight (lb / kg): 3992 / 1811
Weight distribution
(% front / rear):
62 / 38
Interior
Seating capacity (front / rear): 2 / 3
Head room (in. / mm): front: 38.2 / 969
rear: 38 / 965
Leg room (in. / mm): front: 42.5 / 1079
rear: 38.2 / 970
Shoulder room (in. / mm): front: 59.1 / 1501
rear: 58 / 1474
Hip room (in. / mm): front: 55.6 / 1412
rear: 57.5 / 1460
Capacities
EPA interior volume inc. trunk
(cu. ft. / L): 119.9 / 3395
Cooling system (qt. / L): 12.5 / 11.8
Fuel tank (gal. / L): 18.5 / 70.7
Engine oil (qt. / L): 7 / 6.6
Towing capacity (lb. / kg): 2000 / 907
1 - 1 of 1 Posts
