Am I just an idiot
  • Total voters
    1
2013 AWD ATS 3.6 Performance
On the hunt for coilovers for my '13 AWD 3.6, and there are substantially more options for coils for the RWD ATS. Not sure if I'm really up to spend a grand on a set of BC Racings when there are cheaper options. Why are there so many that are only designed for the RWD? Can I install them on mine?
2014 ATS 2.0T 6spd manual Performance RWD
I think most kits are specified as being engineered for the 2.0T RWD, I guess companies just figured that was the one most people would be modifying since it had an available manual transmission and turbo/tuning potential. From what I have seen, most everyone who wants suspension on their AWD has resorted to buying kits specified as being for the RWD, whether V6 or 4cyl. I think lowering springs make the car sit a little differently front and rear depending on if its AWD or RWD, but with full coilovers you can dial in ride height so that's not a concern. That said, I would go for the full coilover option for your car. And yes, they should fit fine unless you have MRC, then I think that might complicate things but I'm not sure.
'16 ATS-V MT6 Sedan, Alfas: '67 Duetto, '84 GTV6 3.5L 24v/Vette C5 project
.... I think lowering springs make the car sit a little differently front and rear depending on if its AWD or RWD, but with full coilovers you can dial in ride height so that's not a concern. .... And yes, they should fit fine unless you have MRC, then I think that might complicate things but I'm not sure.
I was under the impression that MRC wasn't made available as an option for the AWD configuration .... ?
For anyone curious, I was able to install coilovers that were "only designed for the RWD model" on my AWD. It's the same setup. Message me on IG if you have any questions!
@iudbaby
