06 CTS-V (sold)
Just got my car up and crawled under it for the first time. Ready to swap out the factory fluids and want to make sure I know what I'm doing before I start. Looking for a little help from those that have gone before me. Would appreciate confirmation of the below:
Diff
Fill plug: driver's side just in front of the half shaft, about halfway up
Drain plug: centered on the bottom
Tranny
Fill plug: driver's side, about halfway forward and halfway up
Drain plug: passenger side, rear corner on the bottom with what looks to be the temp sensor plugged into it.
There is another plug on the tranny passenger's side top forward - is this the 1st-4th skip solenoid?
Started with '04 BR V, moved on to '09 Slvr V, now '13 CRT coupe
Diff
Tranny
See if this info helps:
Changing transmission fluid
Changing differential fluid
even got piktures!
There is a reason why you want to get the gear lube nice and toasty warm before attempting to change. Your fill/drain plugs are made of steel and the transmission'differential cases are aluminum. These dissemilar metals expand differently and when cold the plugs are very, very tight - too tight to attempt loosening usually.
Always, always, always loosen the fill plug first. Then, if by chance you cannot loosen the drain plug - no worries.
06 CTS-V (sold)
OldRoadDawg,
Thanks for the links, great info. Pretty much confirmed what I saw this morning.
Rey,
Thanks for the tips. Learned the same things on my Z06 years ago... and haven't forgotten them. :cheers:
