1 - 9 of 9 Posts
1994 seville sls
1994 Seville 132K. I put Chevron fuel injector cleaner into a little less than a 1/2 tank and run the tank very low before refilling. A few days later major stalling problem where I had to "power brake" at stop lights to keep from stalling (9 mile commute to work it actually stalled around 4 times). When I made it to the parking lot (car ideling rough) I revved the engine pretty hard thinking I had something blocking an injector or EGR because of the fuel injector cleaner. A huge plum of smoke ensued it appeared from all around the car. Starting ideling fine and running well. However its now running approx 15-20 degrees hotter than ever before on my 9 mile daily commute to work.
Not quite ready to invest the time or money for a block test. So did my actions possiblely damage the head gasket.
Thanks for all you guys do for caddi owners.
A Lisle block test kit is ~$20 on Amazon. It takes about 10 minutes to perform the test.
you can "rent" the test kit for free from autozone and other chain stores -
just pay for the blue juice - around $10 -
No. TECHRON is a high quality fuel system cleaner endorsed by GM. The ingredients put it in the snake oil category, but it won't "blow a head gasket". Northstar head gaskets don't actually "blow" anyway - read the stickies on the problem in Northstar.
Poor idle, ragged running, sudden smoke, clearing up - sounds like a partially clogged cat. The warmer (what actual temperatures ???) engine coolant may or may not be due to a slew of problems - bottom line: Is it steadily losing or blowing out coolant ?
1994 seville sls
This incident actually occurred last Thursday. I will recheck the coolant level again tomorrow morning. The usual temperature displayed for my 9 mile commute is 196 to 198. Now is 10-15 degrees higher after revving the engine pretty hard but not red lining.
that will not hurt the engine -
or cause head gasket failures -
If redline operation would hurt the Northstar, mine would have been dead any time since 11/21/05 - the afternoon that I bought the car - and nearly every drive since. (BUT - there were one hell of a lot of changes made to the Northstar from '94 to '02)
2010 DTS
Have you cleaned the TB?
Have you checked the coolant level and the purge line?
1994 seville sls
Discussion Starter · #9 ·
TB was cleaned at 117k Coolant level good and a visual inspection of cooling system related items appear in good working order.
One other item with this vehicle is I've always had 15.7-8 mpg on the dash read out. Now its 14.5. That why I added the fuel injector cleaner.
All necessary tune up items were done at 117k.
1 - 9 of 9 Posts
