awesome. since the pan was dropped on the tranny, for the next few weeks watch the fluid like a hawk! reason - if the pan wasnt 100% seated, it may leak after a few hours, days, or couple hundred miles. usually the heat and cool nature of the on and off will bring out a not completely sealed seal problem. if the fluid was burnt, more reason to keep tabs on it. if it gets dark or burnt again too soon, you may have some issues. alternator id recommend AC delco or BRAND NEW not any other thing thats refurbished.... unless its refurbished by AC delco or BOSCH. just speakin from experience. the alternator prolly makes noise because of bad tension as a weak/worn belt, tensioner springs that lost there strength, worn idler pulleys, etc. or, ya could have gotten a fluke alt. either way glad to hear your rollin again
the 1990 is a 4.5 correct? use AC DELCO plugs, wires, etc. it came from the factory with platinum plugs... keep that in mind when changing them. isc is an easy fix... dont forget the easy stuff! like PCV valve, EGR valve cleaning, fuel filter, air filter, etc etc etc... while your changing the plugs and have all the stuff off anyways it never hurts to make sure the pcv valve rattles when you shake it, that the hoses arent cracked, etc. changing the back plugs is an excellent time to check the heater T hoses and all that jazz. EGR valve is held on with two bolts. change that with the correct (and looks EXACTLY the same) part. not the silver aftermarket ones. itll throw your car crazy! and the light may come on as both of mine did. + on rockauto.com the egr valve is cheaper then the aftermarket one! go figure.
if you need anything else, do not hesitate to ask, or even shoot me an email after you post to get me to look at it faster
[email protected]
Phil
