1 - 17 of 17 Posts
2001 DHS
I noticed today my "SERVICE STABILITY SYS" messaged appeared along with the ABS/TC lights and a ABS C1232 History code. Could it perhaps be from the heavy snow we've had lately? I did a thorough undercarriage/wheels wash however still appears after clearing codes. Any advice?
PS: I changed the driver side CV Axel/bearings about 2 months ago and the passenger side CV Axel/bearings about 3 weeks ago, would that be the culprit?
No it's not from the weather.
What's the code definition? Steering position sensor?
2001 DHS
Sorry forgot to put the definition, here it is:
C1232 - Left Front Wheel Speed Circuit Open or Shorted
Also, could it be a loose or bad wire harness? If so does anyone know where it's located?
Most likely just a failing/failed wheel speed sensor. You can inspect the connector/harness, but WSS failure is fairly common.
The WSS is integrated into the hub assembly. Use AC Delco or Timken replacements ONLY.
it COULD be -
but most likely - it's a bad hub -
2001 DHS
Discussion Starter · #6 ·
Do you happen to know the part number for AC DELCO?
2001 DHS
Thanks Bass, do you recommend I do both driver and passenger side? Are these universal for both sides or left and right each have a different part number?
The sensor is on the hub? if not, how could I know if the sensor needs to be replaced or the hub?
not unless both are bad -
there is no "overlapping" labor -
you save nothing by doing both at the same time -
YES -
both front hubs are the same - and both rears are the same -
YES - it's all one sealed assembly -
2001 DHS
Discussion Starter · #10 ·
Please excuse my lack of knowledge.... Is the hub also referred to as bearings or they are two separate parts? Cuz I recall having the driver side bearing changed about 7 months ago and has a 1 year parts/labor warranty on it
The hub is what you see when the brake rotor is removed, the small round disk with the wheel studs sticking out of it. Most passenger cars use a hub/bearing assembly, where the hub and bearing are one sealed, unserviceable bolt in unit. For the most part, heavier vehicles are the only application where you'll see the older style system, where you remove the hub nut and hub to service or replace the bearing separately.
In many vehicles with hub/bearing assemblies, the wheel speed sensor is an integrated, unserviceable part. That's the case with these cars.
The reason for the Timken/AC Delco recommendation is that other brands usually just don't last very long at all. A warranty is fine and all, but worthless if you have to keep changing the part.
2001 DHS
Discussion Starter · #12 ·
CONCLUSION: Took the hub bearing out and noticed the wire was in contact with an object and had gradually worn off. Replaced the bearing and all is good now. Thank you all for your feedback
===============================:highfive:
2001 DHS
Discussion Starter · #14 ·
UPDATE: Tonight I was in an open parking lot testing the stability system in snow (as I randomly do) and noticed the stability system kicks in 1-2 seconds later than it did before I change the hub. Could it be because of the aftermarket Hub and the signal it sends/detects?
1-2 seconds later than what? There is no set time at which the system steps in. There are many variables.
And FWIW, if the WSS in the new hub assembly wasn't working as well as/ differently than the original did when new, it would set a code.
2001 DHS
Discussion Starter · #16 ·
Before immediately as I would go into a slippery turn my Stability message would appear and right away it would engage. Now the same maneuver takes about a second or so longer for it to kick it, making the car go into a good overstear before it engages
2001 DHS
Discussion Starter · #17 ·
In the past when I would purposely try to make the car lose rear control in snow the Stability system would immediate kick it, however now with the same maneuver it takes about a second or so later for the stability system to engage and the car would actually go into an oversteer before the stability system actually engages. The only thing I can think of that's changed is the recent from hub bearing (NAPA brand)
1 - 17 of 17 Posts
