1 - 20 of 20 Posts
2003 Deville base
I have a 2003 Cadillac DeVille and I'm looking at replacing my shocks are these direct fit for my vehicle and I'll still be able to use my air compressor with them in the back?also does anybody know a good set for the front? Thanks
Re: Cadillac deville monroe ma822 shocks
Monroe MA822 is an excellent choice -
MONROE 71685 for the front -
there is a $60 rebate for 2 struts and 2 shocks -
http://www.rockauto.com/Images/CurrPromoFiles/2015_Monroe_Take_Control_Rebate_Pad_-_US[1]-4.pdf
2003 Deville base
Ok sounds great thanks and how hard is it to do all 4 of these I've done them on my Dodge Ram before
2010 DTS
The rears are easy. The upper mounts are in the trunk and the MA822's are a plug n play with your auto leveling system. Put them on my '03 DHS and my wife's '05 LeSabre and have no complaints. They ride like factory.
.......... front struts, rear shocks with leveling bladders.
2003 Deville base
Discussion Starter · #6 ·
Ok.i am getting code rimco660.will new shocks fix this .I do hear my Compressor motor come on when the car is in park as well as driving sometimes
it is customary to include DEFINITIONS along with any codes you post -
judging by the code definition - NO -
2003 Deville base
Discussion Starter · #10 ·
if my compressor comes on I would think it would be ok? can I just replace the solenoid or the vent?
2010 DTS
If the compressor is turning on without adding a load, then there is a leak in the system.
If a load is removed and the system does not vent and the rear end stays high, then the problem is the vent solenoid or valve and can be serviced separately (if you can find one).
2003 Deville base
Discussion Starter · #12 ·
Ok thanks I know the compressor I need and the shocks do you know what hoses I would get if I need to replace them
the air lines are rarely a problem -
your code C0660 -
suggests the problem is within the compressor assembly -
if you don't want to spend $235 on a new compressor -
you could buy the Monroe AK29 manual fill kit -
around $12 - and inflate/deflate the rear shocks mamually - as needed -
it's exactly like inflating a tire -
2003 Deville base
Discussion Starter · #15 ·
okay that sounds like an idea maybe if I manually fill them how long do you suppose they will stay full or do I have to fill them quite often
if the system is "tight" -
the only reason for changing pressure -
would be to compensate for added - or reduced weight -
in the back seat and or trunk -
2003 Deville base
Discussion Starter · #17 ·
Ok since I've had the car (about 2 years)I've always had the rimco660 code and whenever I've had passages in the back it never really sags low at all
and your point is???????????
point Is.... thinking I may just leave it alone if its not harming anything
I suppose doing nothing is always an option -
1 - 20 of 20 Posts
