1983 coupe deville
Hi all, I have a converted to rhd car. But the column is smashed and I need to get the horn going.
What are the colors for the horn wires? I am putting in airhorns and want to use the horn switch on the steering wheel.
Any diagrams or wiring know how would be great
78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
My 80 electrical manual shows horn circuit breaker being a 30 amp, hot at all times. Wire leading out from there is
Orange with a black stripe to horn relay. Two wires lead out of that, one being solid green and the other black with
orange stripe to horn switch..which is where the horn pad is..the solid green leads to each respective horn
1983 coupe deville
Thanks for the info!!
So in theory I could wire the solid green directly to the air horn pump? Or still run another relay for the pump?
Nope..because the stock horns do not work off a pump. Youll need seperate horns. Dont think youll need another relay, the stock one would be fine...
