Re: Cadillac deville 1995 ped 14
Found a connection unplug that says ped 14 where does it go help please
that might be the ground wire used to program the remote -
Deville 1995
basscatt said:
===================== that might be the ground wire used to program the remote -
the remote opens the trunk and the trunk release button works fine thanks tho if you get more ideas what it can be I will really appreciate it thanks for your answer tho
No, the ground is used when programming a remote. It has nothing to do with a current remote operating or not. The ground (if that's what that is) is supposed to be disconnected.
If everything works, that's probably what it is.
1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
That is what it looks like to me also.
You ground that wire to program the remotes - Other than that it just hangs around behind the carpet near the trunk pull down motor.
maybe I wasn't clear -
the PROCESS of matching the car and the remotes
REQUIRES grounding that plug you are holding -
that is the one - and only - purpose of that plug -
it has no other purpose - and no other use -
