Deville 1995
Been fixing my cadillac and my mph says 6.8 and my mpg says 3.4 is that low it looks like it to me what could that be barely learning about cars and especially about cadillac trying know more and more about them and my emergency lights ain't working no more I will really appreciate Yall help
· Master of the Dark Art of Diagnostics
Re: Cadillac deville 1995
I assume you are referring to AVERAGE mph and AVERAGE mpg -
when you reset them -
the stored mph and mpg goes to ZERO -
as you drive - the average speed and gas mileage will increase -
if you sit idling - both will decrease -
do da break lites work is da lites all workin is da blinkers blinken on da lef and da rite side does day blink on da front and da back if ya kood be da blinker fer da emerjensee lites -
or - in proper English - with punctuation -
do the brake lights work -
do the turn signal bulbs all work - front and rear -
if yes - the flasher for the emergency lights is probably defective -
Deville 1995
basscatt said:
============================== my mph says 6.8 and my mpg says 3.4 is that low I assume you are referring to AVERAGE mph and AVERAGE mpg - when you reset them - the stored mph and mpg goes to ZERO - as you drive - the average speed and gas mileage will increase - if you sit idling - both will decrease - my emergency lights ain't working no more do da break lites work is da lites all workin is da blinkers blinken on da lef and da rite side does day blink on da front and da back if ya kood be da blinker fer da emerjensee lites - --------------------- or - in proper English - with punctuation - do the brake lights work - do the turn signal bulbs all work - front and rear - if yes - the flasher for the emergency lights is probably defective -
thanks for your answer and yeah all the lights work and blinkers is just the emergency lights that don't so I guess it is defective how do I get that solve if you don't mind me asking
there are two flashers -
one for turn signals - one for the emergency lights -
they are usually located on/around the steering column -
fairly close together -
one is usually round - the other is usually rectangular -
I don't remember which is for what -
turn the turn signal on - follow the sound -
look for the other flasher close by -
Deville 1995
basscatt said:
============================ how do I get that solve if you don't mind me asking there are two flashers - one for turn signals - one for the emergency lights - they are usually located on/around the steering column - fairly close together - one is usually round - the other is usually rectangular - I don't remember which is for what - turn the turn signal on - follow the sound - look for the other flasher close by -
thanks for your help really appreciated
