Dropped off the CTS at my dealership to have them replace the front driver side lower control arm. Yes I know it's a fairly easy repair but I am finding that I no longer have the time to spend 3+ hours pounding on suspension components with a ratchet and a rubber mallet because I dont have adequate air tools.
Anyways the day I dropped it off it was about 18 degrees outside and the engine only had maybe 2 minutes to warm up before I had to drive it. As I was backing out of my driveway I noticed the CEL (not flashing) and mentioned to the service adviser to please check it out and let me know.
Anyways he called today and didn't mention specific codes but did say in order to fix it, they would perform the following services.
1. "de-carbonize" my engine. To me that just sounds like my intake is dirty and needs a good cleaning.
2. fuel injector flush. Again, this just sounds like maybe they are dirty and need to be cleaned.
3. throttle body service. Again, this just sounds like my throttle body is dirty and needs to be cleaned.
My question is, what would you do to fix these issues yourself. No way am I paying someone 600$ for something I can easily do myself. If the check engine light is still present when I get my car back or pops up again as I am driving, I will pull the codes and update the thread.
Note: the past few mornings when it's been cold outside, the engine has had what feels like a misfire. It's stutters for a few seconds here and there. Once it's warmed up the problem is no longer present even sitting at a light. Stomping on the gas doesn't produce flashing CEL.
My timing chains have been replaced and I've only driven maybe 4 to 5k on them.
Thanks.
Thanks.
