Around the plastic base, where the bulb is held into the headlight, there should be a tab for you to press against the housing, then turn the bulb to release it. I know when I switched to the SilverStars and chrome turn signal bulbs, they were on there nice and good. A little bit of pressure while pressing down the plastic tab and they came right out.gort said:Man I can't get my DRL bulbs out! I got the headlight assembly out fine, but I simply cannot get the bulb out!
I don't want to pull too hard, I'm afraid I'll break the bulb.
