I am installing my Blackvue 900X Plus 2 ch dash cam and am having trouble finding a switched fuse in the driver side fuse panel. I had no problem in the ATS-V fuse panel. Apparently many of the fuses that used to be in that panel on the ATS-V have been moved to the trunk of the CT4-V BW. Most all of the fuses in that front panel have key off or unswitched power. So that tap was easy. It is the switched fuse that I am having a problem with. Also the majority of those fuses are now the 3 legged fuses and I don't yet have taps for them. I have ordered some from Amazon, but that doesn't solve the problem that I haven't found one yet that has no power with key off. There are a lot of empty slots given the movement of so many fuses to the rear. Hopefully once I get some 3 legged fuses I can find one that is switched.
If anyone has solved this problem yet, please let me know your solution. BTW, now the PDR can be set to record everytime the key is on so everyone with a PDR now has a front dash cam, but that doesn't solve the rear cam problem and also the PDR is not as wide angle as most good dashcams.
