Dashboard lights on, when engine is off
3K views 16 replies 7 participants last post by  rockhoundrob1
#1 · (Edited)
2009 DTS 125,000 miles
My wife turned off the engine and exited the car. But the climate and radio lights stayed on. Dome light, headlights are off, but radio/climate is still on.
I tried looking for dash relay and cannot find it.
Any ideas what the issue might be?
Edit: Note: the dash light is off now. I almost thought it was the time delay, but it finally turned off after I wrote the original message.
Could it be a glitch, or is there something wrong with the timer delay for the radio/ climate control?
#6 ·
OEM 6 disc CD AM FM XM no NAV. I know the history as the dealer where I worked sold it new and was the only ones to ever work on the car until it came to me.
RAP goes off when you open the driver door. The display stays on. It stays on longer than the interior lights or the headlights. It always stays on and it always goes off after the programmed time. I originally investigated because I didn’t want to show up first thing in the morning to a dead battery. So far no problem.
#7 ·
Sounds like a gremlin in some of the cars. Sorry I was confused about RAP but I'm no mechanic, but what is it that turns off the dome light after like 10 minutes if you leave it on? My wife like to pull down the visor as she exits to give herself one last look over and she invariably leaves that light on.
#9 ·
Mine started doing this a year and a half ago when the battery was dying. It went away for a while after the battery was replaced but does it 90% of the time now. There have been other posts about it, but I don't remember an actual fix being found. Unlike old cars, we don't have a button in the door jamb.
#10 ·
Well it did it again tonight. I have a better idea what I am seeing.
When you are driving at night, there are all these dim lights all around the car showing window button, lock- unlock buttons.
In other words, these symbol lights are on when driving at night, so you can see the knobs, buttons, etc,...
This did not happen last time. It was only the instrument front panel lights. Now it is all night driving display lights. But again, it went off after 10 minutes.
One other thing I noticed is when I open the driver door, the dome light does not come on. I assume the switch is bad that is in the door?
any idea what is causing the night display lights to not turn off? Is there a relay or a timer I can adjust?
#12 ·
Most cars will have a daylight sensor these days, which is used to let the car know when to turn the lights on via automatic control, if you drive into a tunnel during the day, or when the sun goes down and your lights automatically come on at night.
