Greetings!
When i started up my car a while ago i noticed that the only lights on my instrument panel light array that were illuminated when i turned the key were WASHER FLUID, all other lights: CHECK ENGINE, LEVEL RIDE, COOLANT TEMP, OIL PRESS, BRAKE etc...were not working at all, so are the diode for low fuel and the buzzer for the headlights. After checking all fuses i found 2 blown ones, both 20 amps, LTR and GA TRANS. This problem occurred after i had a new carburetor installed. If something short circuited will i have to change all the sensors for my dash ?
