2003 Deville Base
How do I remove the plastic trim piece that goes around the climate control/radio cluster? Do I just pry it gently with a screw driver? I'm trying to find and remedy the source of an annoying vibration/buzz in that area.
yes - start at the bottom corners -
the top slips under the upper trim -
2003 Deville Base
Discussion Starter · #3 · (Edited)
thanks, bass. It popped right off. With a little trial and error, and strategic placement of adhesive backed felt pads the problem is solved. The lower tabs are plastic, but the two upper clips are metal & those were vibrating on the plastic slots.
