1 - 11 of 11 Posts
If the smoke does in fact smell like coolant, than there no doubt there's an internal coolant leak. But a cracked head is very unlikely.
If the mechanic diagnosed the cracked head solely based on the smoke, he's not a mechanic.
· Administrator
Re: Cylinder Head Problems
No idea of any Mom&Pop shops in/near DC. You may be stuck with the 4 Cadillac dealerships and their $110/hour labor rates.
Get in touch with Jake at www.northstarperformance.com to find out if he ships his engine repair parts to a DC shop.
Cracked Northstar cylinder heads are not common. Symptoms ?
'05 DEVILLE DTS
Discussion Starter · #6 ·
The smoke is the only symptom so far. The fluid level was low last week, so I filled it. My car always says CHECK COOLANT, so I did not know. I think the damage happened then. The shop is suggesting an engine swap. I do not want to do that.
What was the coolant level when it was "low"? Full is about half way up the tank.
Does the smoke smell like coolant to YOU? Or is this "mechanic" saying that?
The smoke is the only symptom? So no overheating? Then no damage has been done. Even if it did overheat, even several times, no damage would have been done. (Assuming you didn't just keep driving)
As posted, a cracked head is very unlikely. Even if a head was cracked, there is NO reason to replace the engine. If there is an internal coolant leak, the most likely issue, by far, is pulled head bolt hole threads. The best solution is NOT replacing the engine. It's inserting or studding all 20 head bolt holes, and replacing the head gaskets.
Don't go back to this shop.
97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
I spoke to the original poster this morning. I hope I led him in the right direction.
http://www.northstarperformance.com/studsdealers.php
This is the current list. I have a few shops to add to the list of installers, but nobody in D.C. so far.
Believe me, travel time and cost to a reputable shop who's experienced with these, will save you $$$ and time. Don't trust any amateurs with a Northstar.
If you have any questions I'll be happy to assist by phone (when I have time) and by email or text message after hours. I hope I can assist- thank you
-Jake @ Northstar Performance
'05 DEVILLE DTS
Discussion Starter · #9 ·
I did speak to Jake and he was very helpful. The smoke smells like coolant to me and several others who were there when I started it. The temp gauge had not reached the first notch past normal before I filled it with coolant. It has not overheated since. I contacted one of the installers from the Northstar Performance page and I am waiting to hear from him.
DTS STS deville
Hello, I am new to this forum but I know members have mentioned me on here before. I don't want to step on anyone's toes, but if you haven't found anyone to repair your engine then I can handle it for you. I have been repairing these engines for 20 years. I install inserts or studs and give a full warranty. I'm located in limerick Pa. :)
1 - 11 of 11 Posts
