1 - 8 of 8 Posts
2004 srx
04 srx awd v6 - i have a clicking noise coming from the driver side front while the wheel is turned slightly to the passanger side. it gets louder the faster the speed and the harder the curve. it even does it while going straight and turning the wheel just far enough to put pressure on the steering system. it does not do it while turning a corner at lower speeds. i have checked brakes for loose parts and there is no play in the wheel bearing. Would the noise im hearing possibly be coming from the cv joints. i tried to feel for play in them but there wasnt anything i could feel. there is no vibrations to speak of just the noise but having my 3 year old in the car daily it concerns me.
if anyone could help me with this i would truely appreciate it.
CV joint or wheel bearing and it might just be the other side; front end noises are weird that way. You sure you're not also on the brakes at the same time, stone caught in the caliper?
2004 SRX V6 AWD
Don't have any brilliant insight on which part it is, but these bearing type failures tend to progress fairly slowly. So unless you're going on a lengthy trip, I wouldn't worry about getting stranded.
NONE
I have trouble with clearance on the brake rotors heat shield. One or twice a year I have to bend the shield away from the rotors due to clicking and rubbing. The sound only shows up when loading the vehicle one way or another during a turn.
2004 srx
I am having a similar issue except I have already replaced the CV shaft on both sides in the front. I did find a very worn out tie rod on the side the clicking was coming from...I found that after I replaced the shaft. After my test drive it is still making the same noise. everything else is tight and good. Could a tierod cause this clicking.
Tierods don't click so no its not the issue. Has to be a rotating part.
SRX 07 V8
Read post "sounds like a cow bell under my car" from orandaberg, turned out it was the shield
2004 srx
Discussion Starter #8
I just replaced the tie rod and the clicking quit I didn't think a tie rod would do that either but it did just a thought for others to check out having similar issues
1 - 8 of 8 Posts
