2003 Diamond White ESV
It rides so much better now. No more bouncy ride or thump over hard bumps.
99 Escalade (sold) 03 Escalade EXT (sold) - 07 Escalade EXT
assuming you have an air-ride suspension .... i would think this mod would put ALOT of stress on the air-struts when u hit a bump... no?
No. I'm lowered 3" in the back. the kit came with shock mount extenders so the shock stilkl has the same amount of travel as when i was stock ride height. But since my frame was now 3" closer to the rear end, it would bottom out easier. Hence the cutting of the bump stop brackets.
This is a very good mod if you have a 3" drop helps on big bumps from bottoming out, But this is a must if your dropped 3/5 or lower
