I hate inconclusive experiments, but that's all I have got at this point. The current drain about 450 mA with fully charged battery (12,75v) would drop to 120 mA in somewhere between 15 and 30 minutes. If I disable security system by pulling out 15A fuse the draw will be about 15 mA. I do not care about security, but with the fuse pulled out the dash would not illuminate at all... So, there is 120 mA drain after the car is locked and security system is in charge. Pulling out all other fuses did nothing. I have disconnected all the plugs in trunk just in case. By the way, a $2.99 digital multimeter from Harbor Fraight and a 12V test bulb work very well. Any noticeable current draw will turn the bulb on, and cheap multimeter handled all the tasks very well. Even if you burn it , it is still only three bucks ! lol. The dash draws about 8-9 A and when leveling compressor is engaged the draw jumps to some 15 A, so be careful. A dome light, trunk light, glove box light draw about 0.5A.
I believe 120 mA is till too much (despite I cannot see how it would drain 100Ah battery overnight). Any suggestions, gents? Thank you!
