G
Guest
·While trying to figure out why I was down about 50ish rwHp and cylinders are filling with oil. Found this... It explains the loss of power but not the oil consumption and 20-25% leakdown in every cylinder.
I can't believe you just quoted anything that Texas Speed said. I effing HATE them right now. I hope your shortblock turns out better than mine. My invoice didn't match the build sheet they provided me and neither matched the actual build. Maybe yours will have full compression and not burn 1 qt of oil every 500 miles after 4 months of running.When I called Texas Speed to set up my 418 CID LS3 build, they recommended the Lunati Street Link-Bar lifters as the first step above the LS7 lifters. The next step beyond that is definitely Morel, as Darkman said.
If you really want to go past the Comp Cams upgrade (which I think you should still be fine with), consider Scorpion rockers (LS3 part here), which are apparently well-liked by the Corvette community.
Most people love their Texas Speed shortblocks. If this was a problem from the start, I hope you called them up. Otherwise, I'm not sure what your options are now.I can't believe you just quoted anything that Texas Speed said. I effing HATE them right now. I hope your shortblock turns out better than mine. My invoice didn't match the build sheet they provided me and neither matched the actual build. Maybe yours will have full compression and not burn 1 qt of oil every 500 miles after 4 months of running.
You think I should still be fine with the Comp Cams trunion upgrade? Absolutely not. If you could feel how bad some of these things are you'd be singing a different tune. I think once you get into the higher lift cams and higher rpms you just need something stronger.
Must be right - Go for it.Well, Texas Speed also recommended stock rockers. "This is what we use in our builds".
