I have a 2017 CTS 3.6. I recently had the Cue infotainment system completely replaced beaches it was constantly rebooting. After it was replaced it worked correctly for about a day. Then it started doing the same thing. I’ve done the hard reset. Still the same thing. I noticed it starts doing it when tried to connect to my iPhone. So I turned off the Bluetooth and everything works fine. Any ideas why the Bluetooth may be causing this? This happened with my iPhone X and now my iPhone 11Pro.
Super Moderator 2005 CTS-V
'05 CTS-V
Moved from the '09-15 CTS-V forum. You're more likely to get help here, since the 2nd gen CTS/CTS-V didn't even have CUE.
2015 SRX LUX 2014 CTS LUX Phantom Grey (previously 2008 STS)
Its not your bluetooth its your iphone
Having the same problem. Dealer replaced CUE but problem continued. I found that there seems to be a compatibility issue with IPhone’s latest operating system IOS 13 and CUE. Every phone with IOS 13 drags down the CUE. I then tried older phones with older operating software and they work fine.
Premium Member
2016 ATS 2.0T Luxury RWD
What happens if you connect using a cable? No problems here with 11Pro Max (latest software) & a '16 & a '19 CTS, either Bluetooth or hardwire.
Premium Member
I would ask the dealer if all the Bluetooth-related wiring & hardware was replaced when they replaced your Cue system. I can't see how your phone's bluetooth would cause the vehicle's system to reboot. Regardless, your car is still under warranty & they should be able to fix it.
