1 - 12 of 12 Posts
I have a 2015 ATS 2.0L. My CUE screen is doing this thing where all of a sudden, it will act like someone is pressing the preset radio station in the middle of the list. And the row of presets will move back and forth like someone is touching the screen with a shaky finger. It also beeps and provides that haptic "bump" every few seconds like I'm setting a new preset. I've cleaned the screen because I thought maybe there was a smudge that it was picking up as input. When this occurs, I can change the station with the steering wheel button, but the screen is unresponsive. And this only occurs on the radio screen. This behavior does not occur on any other screens, and can last anywhere from a few seconds to a few minutes. It eventually goes away. I had the screen replaced once under warranty, but now I'm out of warranty. Any ideas?
2017 ATS Premium Luxury
You need a new screen. Common problem on these cars. If you’re handy, you can DIY for about $50-$150, depending on where you buy your replacement screen. Dealer will charge about $1200 and replace the entire center stack, which really isn’t necessary.
mpreissner, thanks! I've seen videos of how to replace the screen, and it's actually easier than I thought. I also found a replacement screen for $149 at https://www.germanaudiotech.com/pro...lac-ats-cts-srx-xts-cue-touch-sense-2013-2017. Do you know if that's a good place to get one, or are there better vendors?
I would recommend Cue Screens. I purchased their premium version for $130 and have no complaints, works perfectly. Regardless of the brand you go with, just don't go cheap. Some of the knock-offs lack the proximity sensors.
https://www.cuescreens.com/?gclid=EAIaIQobChMI9fTphtiM5QIVYiCtBh2tKASJEAAYASAAEgIBHfD_BwE
ATS
I have a 2016 2.0 T and have the same problem. I have reported the issue to my dealer, and was unsuccessful in getting the malfunction to happen when I was at the dealer. They seemed to be unware of any problems like this. I'm only about 6K miles from the warranty expiring. Is there any service bulletin on this topic?
2013 ATS 3.6L Luxury
There is a TSB for dead spot on CUE and I think another for cracking/delaminating, but I don't think I've seen one for ghost touching. Try to get a video when it's happening.
2016 ATS4 2.0T and a bunch of other stuff....
I love it. Problems to the extent of a class action lawsuit ant they're not aware. My original dealer, after replacing mine, told me "Yes, it will happen again".
I have a 15 ATS coupe, and my CUE started doing the exact behavior as the OP. It was very random. I bought a new screen from cuescreens.com. I just installed it last weekend. It took less than an hour, and everything is functioning fine. Hopefully with a screen that has no gel in the middle, this issue is gone forever.
Discussion Starter #10
itguy, thanks for the info! Which one did you buy, the premium or basic? If you could, give us an update and let us know how it's doing long-term.
I purchased the premium ($130) screen from cuescreens about half a year ago. My install took probably 2 hours, but I was taking it slow and doing things carefully. So far, zero issues and zero complaints. Everything is working perfectly.
Discussion Starter #12
Good to know! My first screen acted up within the first two years of ownership. The current GM replacement started about another two years later. It's pretty sad that we apparently can buy better screens for $130 than GM can provide. Thanks for the update!
1 - 12 of 12 Posts
