My 2019 XTS continues to receive Bluetooth connections from unwanted devices. I delete them manually from the system and in a few weeks, I have several more of these unwanted connections. How do I prevent unwanted connections??? Thanks for replies.
Thanks for the reply. This morning I deleted 4 unknown phone connections to my CUE / Phone device. My phone connects just fine but when I go later to connect the CUE does not list my phone but does list other unwanted phone connections. I have to reconnect my phone. I can delete these phones but others will appear later. The car is sitting in my driveway!!! Any suggestions??Please elaborate indicating the type of unwanted device connections. I have not experienced this at all except for one occasion when a tech was working on my car and it listed his cell phone. I think he paired it to test something out, but in the process unpaired mine, lol.
Here's what I have done. Went out this morning and erased all connections in the CUE / Phone listings, connected my cell phone which showed as the only phone in the listing. Under Wi-Fi Networks no networks were connected ("Not Connected"). Under Wi-Fi Hotspots, "Wi-Fi Services Switched Off", "Connected Devices 0 (zero)". I turned off the vehicle and went inside. Three hours later I went back to the car and my Connected Phones listing was full of unknown phones and mine was not listed. Just repeated the same process. Will recheck again in a few hours. Any help or suggestions???? Thanks in advance.At the moment my only thought is that the vehicle's Wi-Fi hotspot is picking up other connections, but I don't know why your phone would loose it's pairing, unless it has gone over the limit on the number devices allowed and as a consequence dropped yours due to it being the first one. You could try; CUE > Settings > System > Wi-Fi Services, which allows devices to use the vehicle hotspot. You can select 'disable' in CUE. If it is already disabled, then I don't know what the cause would be.
I'm sure there must be an explanation, but I don't know it at the moment. Dealership maybe?Here's what I have done. Went out this morning and erased all connections in the CUE / Phone listings, connected my cell phone which showed as the only phone in the listing. Under Wi-Fi Networks no networks were connected ("Not Connected"). Under Wi-Fi Hotspots, "Wi-Fi Services Switched Off", "Connected Devices 0 (zero)". I turned off the vehicle and went inside. Three hours later I went back to the car and my Connected Phones listing was full of unknown phones and mine was not listed. Just repeated the same process. Will recheck again in a few hours. Any help or suggestions???? Thanks in advance.
Found a contact I will try tomorrow: CUE Information Team, 855 / 428-3669 (8am - 10pm, 7 days a week). Will see if they can assist. Appreciate your responses. Thanks.I'm sure there must be an explanation, but I don't know it at the moment. Dealership maybe?
Let us know what the solution is!Found a contact I will try tomorrow: CUE Information Team, 855 / 428-3669 (8am - 10pm, 7 days a week). Will see if they can assist. Appreciate your responses. Thanks.
