As all of you know, the CTS-V has more HP than tire to handle it. I want to increase my tire size (width, not diameter) to gain some off-the line traction. My plan is to run 275/35/19's on the front using 10x19 wheels and 305/30/19's onthe rear using 11x19 wheels. These sizes yeild about the same OD as the OEM set-up with increased width. My concern is what offset I should use to get the necessary suspension/body clearances and if I can fit them at all.
Has anyone fit similar sized wheels / tire on their CTS, how did it work out for you, and what offset did you end up with?
Thanks for your help
