Today I took my 03 CTS to the shop for new tires and alignment. I had no problems leaving the shop but after my first stop I could not get it to shift out of park and none of the brake lights were working. I was able to open the shifter boot and manually disengage the lock and drive home. I researched forums and tried most of the recommended fixes with no luck, so any input would be greatly appreciated. So far I have tried: checking ohms on the brake light switch and the cruise control switch closed and open (they both seem to be functioning fine), Checked all fuses in the rear fuse panel and disconnected battery. I don't have a code scanner on hand, but I'm not getting any warning lights on the dash. I will try and get it scanned tomorrow.
Thanks!
Joe H.
Thanks!
Joe H.
